Sponsored by: CARiD
96 discovery passenger side window doesnt open
Old Dec 24, 2006 | 03:35 PM
hatanhi's Avatar
4th Gear
Default 96 discovery passenger side window doesnt open
Hi. I'm wondering if anybody can help me.
I have a 96 Disco with 110,000 miles. My passenger side window just stopped working. All other windows are working. I've swapped the switches with the other windows and that does not work. Fuses seem fine too.
Could this be a connection problem within the door? If so how do I get the door panels off? I tried to pull it off, but heard a "crack" so I did not pull further.
Thanks for any help.
Hatanhi
Old Dec 24, 2006 | 03:43 PM
Default RE: 96 discovery passenger side window doesnt open
Is the window motor working, making a noise? You most likely have a bad window regulator which will not all the window to roll up. Check and make sure you have power to the window regulator and if so replace it.
Mike
Old Dec 25, 2006 | 02:04 AM
hatanhi's Avatar
4th Gear
Hi. The motor doesn't many any noise, as if there is no power at all going there.
How do I check the regulator?
Thanks
Hatanhi
Old Dec 25, 2006 | 11:24 AM
If the motor is quiet don't worry about the regulator. Get a test probe and starting check for power to the switch and the window motor.
Mike
SuperSport
Jul 23, 2014 01:04 PM
Marni
Sep 15, 2011 10:03 AM
pilsner
Jan 26, 2009 09:06 PM
bcolins
Oct 2, 2008 12:36 PM
