96 Range Rover 4.0 engine isnt getting gas?
I have a 96 Range Rover 4.0 and i bought this car 6 months ago. The engine is fine, but it seems to not be getting gas. I have been told that it is probably the fuel filter or the fuel injection. I know for sure that it is not a fuse all of the fuses are working properly. Does anyone know where i can go to get this fixed for cheap. I live around the Nashville, TN area.
Thanks, Andy
Thanks, Andy
if its like a disco it has a roll over fuel cut-off switch under the hood. i found the one in my disco tripped a couple of times. if your RR has one it is probablyon the firewall looks like a relay with a black rubber covered button on top.push the buttonto resetthe power to the fuel pump. just a guess. you should be able to hear the fuel pump power up and prime the system when you turn the key to run. (shut off radio, roll down windows and close doors to turn off buzzer) if you hear the pump then the cut-off switch is not tripped.
If you can't figure out the problem, call me later this morning and I'll walk you thru a number of things to tst or check.
303-862-7680
303-862-7680
