Sponsored by: CARiD
96 Rover Se A/C issues ????????
Old Feb 20, 2008 | 03:00 PM
troopermc's Avatar
Default 96 Rover Se A/C issues ????????
96 rover se 4.0. A/C was ice cold, now compressor will no come on. When I cross the wiring on the top of the compressor, the compressor comes on and blows cold. Any ideas? common problems on these? any help appreciated!!
Old Feb 20, 2008 | 04:02 PM
Default RE: 96 Rover Se A/C issues ????????
Could be low on pressure or in fact have a bad pressure switch. Another possibility would be your electronic fan, if it has failed and won't come on, the ECU won't let the compressor to activate.
Old Feb 20, 2008 | 08:36 PM
troopermc's Avatar
is the elcetronic fan for the heat as well? if so, my heater is working fine. Ill start with the pressure switch, where is it located?
Old Feb 21, 2008 | 08:15 AM
okdiscoguy's Avatar
The fan is in front of your radiator. What "rover" do you have? Discovery or Range?
Old Feb 21, 2008 | 09:23 AM
Don't just start throwing parts at it. If you aren't familiar with the system and how to test it then take it to a small shop that works on them and is familiar with testing.
Old Feb 21, 2008 | 09:32 AM
troopermc's Avatar
ORIGINAL: Disco Mike
I totally agree, and i took it to the only Land Rover repair shop I could find in my whole state and after $425 they couldnt figure it out. They installed some type of "tri" ?? valve and recharged the system, but it still wont come on without hot crossing the wires. So, I took it home to my shop and am trying to diagnose it before I waste any more money on it. It is a 96 Range Rover 4.0 SE.
ckwgreb77
Jan 31, 2008 09:29 AM
vwtech
Oct 12, 2007 12:46 PM
clacaria
Mar 18, 2007 03:26 PM
weigellj
Mar 28, 2006 11:51 PM
fidel309
Oct 9, 2005 03:41 AM
