Sponsored by: CARiD
'97 D1, front end Wobble...
Old Apr 22, 2011 | 09:54 PM
adigerol77's Avatar
Default '97 D1, front end Wobble...
So at hwy speeds I'm getting a wobble, pretty sure it's the front drive shaft, apparently I can get it rebuilt for $200, or buy new for $1200. Anyone had one rebuilt? Pros/cons? Thanks in advance.
Old Apr 23, 2011 | 07:06 AM
antichrist's Avatar
A bad front propshaft won't cause wobble. It will cause a vibration.
Wobble is caused by one or more of these:
bad tires
worn suspension bushings
loose hub bearings
too light swivel pin preload
loose steering components
Note: A bad steering damper does not contribute to wobble.
Old Apr 24, 2011 | 11:05 AM
adigerol77's Avatar
bad tires
loose hub bearings
It's actually more a vibration than wobble, bounce if you will. But I'll have all those checked before having the shaft rebuilt and see what happens. Funny enough, I was looking through the RAVE manual and sort of had the feeling some things were worn, especially with 120xxx miles on it.
Kind of nice though, this disco has lived it's entire life in AZ so there's no rust. But I'm a bit concerned with the DL, I've not tried throwing it into 4L yet, have a feeling it's never seen dirt and I'll wait and let my mech throw it into 4L, just in case it sticks.
kenk
Jun 17, 2015 07:47 PM
kenk
Feb 15, 2010 09:51 AM
pelias
Aug 13, 2008 04:54 PM
stephenibiza
Defender
Dec 2, 2006 05:36 PM
The Image
Sep 25, 2006 11:05 PM
