Sponsored by: CARiD
97 D90 power steering leak
Old Apr 18, 2011 | 08:23 PM
JoeLo22's Avatar
Thumbs down 97 D90 power steering leak
Anyone have experience addressing a PS leak on a 1997 D90? I'm curious what the fix should cost me to replace the hose and do a full flush. Can I expect the cost to be more parts or labor heavy?
Thanks!
Old Apr 18, 2011 | 09:02 PM
Land Rover Defender 90, 110, 130 Steering Pipes, Hose Parts Available from RoversNorth.com
Its a easy DIY, if you want first you can start topping off the system with Valvoline MaxLife ATF.
The Power steering system on Defenders and DI's use ATF (automatic transmission fluid, Dexron III)
I started using it and it slowed my leak to almost nil.
Old Apr 18, 2011 | 09:05 PM
JoeLo22's Avatar
Thanks for the tip Spike. Any special LR tools needed for the DIY repair or will the common tool box items get me through?
Old Apr 19, 2011 | 09:09 AM
You need to take some time and find the leak, come on, you can see it and all we can do is guess. You have 3 hoses, a p/s pump and the p/s gear box, any of which can be leaking, how can we give you an estimate?
Don't let it run low and get it to a good mechanic, not the dealer and plan on spending some possibly big money since you haven't found the leak.
Old Apr 19, 2011 | 07:06 PM
Common tools Joe, thats all you should need.
johnnyjohnny
Sep 26, 2019 09:37 PM
DiscoBritney
Dec 19, 2011 06:24 PM
orionpaxx
Nov 7, 2011 10:07 PM
losinov
Mar 21, 2011 08:57 PM
jycsalas
Apr 17, 2009 02:21 AM
