Sponsored by: CARiD
98 Disco starts, runs a bit, sputters and stops!
Old Jul 7, 2006 | 09:35 PM
PK's Avatar
PK
Default 98 Disco starts, runs a bit, sputters and stops!
Hope someone can help me with this. Taking my Disco to the dealership is getting too expensive... gotta start learning how to fix problems myself.
My Disco has started doing the following...
1. Starts then sputters then stops.
2. Starts then runs for a while then stops.
3. Starts then runs for about a week then starts the whole sputtering and stop thing again.
I'm a computer guy but haven't gotten into troubleshooting cars much. Any idea where I can find a manual without breaking the bank? What sort of tools do I need to work on my Disco?
Thanks!
Old Jul 7, 2006 | 10:35 PM
Default RE: 98 Disco starts, runs a bit, sputters and stops!
How many miles on the truck, what sort of tune related service, has the fuel flter been changed, plugs and wires???
Mike
Old Jul 8, 2006 | 01:03 AM
PK's Avatar
PK
77K on the Disco. It has been tuned by the LR dealership a few times. Last time was at around 70K. That's when they replaced the power steering pump. To my knowledge the fuel filter, plugs and wires have not been changed. Spark plugs and wires seem like they would be fairly easy to replace... but the fuel filter? Is that difficult?
Thanks!
Old Jul 8, 2006 | 10:16 AM
Not that the plug wires will correct this problem, but ar 77K, they are warn out and not helping your trucks performance.
The fuel fiter, which on D1's is known to cause some of what you are experiencing, is located in the right rear wheel well on the frame. Rasy to replace as long as you spray a little penetrating oil on the 2 fittings the day before you replace it. It is a common filter that can be found at most auto part stores.
I would also suggest you buy e cans of SeaFoam to help clean out your engine really well.
If you have any questions, we can talk this weekend.
303-862-7680
Mike
ajnolin
Dec 2, 2013 11:26 PM
Titus Crabb
Aug 13, 2012 09:48 PM
Darover
Sep 16, 2008 02:24 PM
christians1600
Dec 16, 2007 10:37 AM
whodey
Mar 6, 2005 01:49 PM
