98 Disco won't shut off
Had 98 Disco 3 weeks. Land Rover had it for 2 of them. It quit starting and the dealer charged me $800.00 to replace the ignition box under the hood. Got it back and it would not shut off. They told me it had the wrong key switch and it would be another $700.00 to replace that. The dealer had to jump start it when I picked it up too. I drove it home and replaced the ignition switch myself. It still won't shut off without pulling the fuel pump fuse. Now it has a parasitic battery drain too that wasn't present before the dealer got it. While tinkering with it today, it also started sputtering and dying while trying to drive it. Sometimes it will run like a scalded cat and other times it acts like it has a horrible fuel problem. Any suggestions would help me head in the right direction. Thank you.
The wire in the fuse box that was shorting everything appears to be a wire somebody added to power the fuel pump. When the dealership replaced the fuel module under the hood, it got power like it should and back fed into the fuse box.
The fuel issue has straightened itself out for now. I don't know what the deal was. Possibly bad gas, or it's just waiting to attack again when I'm not looking.
I'm done with the dealership, they screwed me and they know it. I couldn't get anywhere with them.
haverhillguy
02-11-2010 08:24 AM
