Rear wiper won't shut off
Old Mar 16, 2012 | 06:07 PM
bdevr's Avatar
Angry Rear wiper won't shut off
As the title says, my rear wiper won't shut off. It is stuck on slow delay. I can turn it up all the way and back down, but not off. I've fiddled with the switch, turned the truck on and off and pounded my head off the steering wheel, but shockingly enough none of that has worked.
For now the fuse is pulled, but I can still hear the relay clicking every 20 seconds or so. It's beginning to drive me mad like something out of an Edgar Allen Poe story
Old Mar 16, 2012 | 06:24 PM
wyrdvans's Avatar
Does it run when the ignition is off?
I had a problem where the rear wiper would go on when I hit the brakes while my front wipers were on. Turned out to be rear bulb that was out along with some corrosion in the socket that turned the reverse light on when I hit the brake which in turn made my rear wiper wipe because the BCU though I was backing up while my front wipers were on.
That was a head scratcher until I checked the lights.
Old Mar 16, 2012 | 08:23 PM
Connector C079 is the back of the switch, just 2 wires, it switches that point to frame ground and tells the BCU you want the wiper on, the BCU handles everything else. If you unplug the switch and it stops, bad switch. Or could be ground on the orange/black wire which goes back to ECU.
File Type: pdf
Old Mar 17, 2012 | 11:32 PM
bdevr's Avatar
Thanks for the replies. As soon as it stops snowing I'll check it out!
Old Mar 18, 2012 | 06:20 AM
If you fear it is causing a problem wiping when dry, remove fuse F15 in the under dash fusebox.
Old Apr 8, 2018 | 07:48 PM
neenter's Avatar
Default Push the “stalk” forward to turn off.
Push the stalk forward to turn off
Old Apr 8, 2018 | 10:17 PM
JUKE179r's Avatar
I hope the OP found his answer from 6 years ago. Lol
Blackbanshee32
Apr 22, 2015 04:04 PM
Alabama Butthead
Oct 23, 2013 01:02 PM
thehun
Dec 27, 2010 03:41 PM
haverhillguy
Feb 11, 2010 08:24 AM
AmyRover
Dec 13, 2009 01:03 PM
