Sponsored by: CARiD
'99 Disco II IMMOBILIZED...HELP!!!
Old Jun 21, 2008 | 04:01 PM
Gulfviews14's Avatar
3rd Gear
Default '99 Disco II IMMOBILIZED...HELP!!!
Here we go, I bought a used Disco II and have only had to change the oil pump, everything else is great. I do not have the FOB nor do I have the remote so needless to say, she is on lockdown and I cannot get her started. The closest dealership is 90 minutes away and it is Saturday!!! What do I need to do to get her started again!!!!!!!!!!!!
Old Jun 21, 2008 | 04:58 PM
roverguy7's Avatar
Default RE: '99 Disco II IMMOBILIZED...HELP!!!
lock and unlock the doors with the key, watch the alarm led and see what it does. if it stays lit then you are going to at least need a door latch, its not sending the signal to mobilize the vehicle... if it turns off and then after 20 seconds starts to flash every 2 seconds, then passive immobilization is active, and it shouldnt be, any dealer can turn this off, and should do it for free, its a known problem with this car and theres a tech bulletin/service action to fix it, however if this is the case, it should start within those 20 seconds... try it and see what happens
Old Jun 21, 2008 | 05:02 PM
3rd Gear
I tried that already and the rapid flashing went immediately to the 2 second flashing. The closest dealer is an hour and a half away. Would they walk me through it over the phone or is there some special tools needed to reset it? Thank you for the response.
Old Jun 21, 2008 | 05:10 PM
They will need to use their Test Book to clear it.
Old Jun 21, 2008 | 05:12 PM
3rd Gear
So I pretty much have to have it towed/hauled to the dealership...
Old Jun 21, 2008 | 05:45 PM
roverguy7's Avatar
does the alarm go off? and actually they need to use the hand held t4, regular testbook wont do it
bulletsnbait
Mar 20, 2022 06:30 PM
CRB357
May 12, 2015 07:15 PM
Roverman7
May 19, 2013 08:42 PM
southfloridadiscoII
Jul 18, 2011 07:41 AM
southfloridadiscoII
Jul 17, 2011 08:54 PM
