2001 disco immobilized HELP!
Old Jul 17, 2011 | 08:17 PM
southfloridadiscoII's Avatar
Angry 2001 disco immobilized HELP!
Disco would not start after a jump. Battery checked out with dead cell. Changed battery now immobilized. Wont turn over at all. Please help! several attempts at turning key 1-5-1-5. Anybody have any ideas? who has the correct mobilization codes? Happened once before but I called atlantic british and the guy walked me thru the procedure.
Got to leave early in the morning. Please help
Old Jul 17, 2011 | 08:54 PM
Have seen some posts that suggest pressing the inertia switch on the firewall several times. Also saw this in the RAVE download, hope it helps:
ALARM SYSTEM AND HORN
86-4-22 DESCRIPTION AND OPERATION
The code is recorded on the security information card and is entered as follows:
Using the key, turn the driver's door lock to the UNLOCK position and hold in this position for at least 5 seconds.
An audible warning is then emitted to indicate that the body control unit is ready to accept the code. Return the
key to the centre position. It is now possible to use the key to enter the separate numerical values of the four
digits that make up the EKA code.
Enter the first digit of the code. If the first digit is 4, turn the key to the UNLOCK position 4 times. Ensure the
key is fully returned to the centre position after each turn of the key.
Enter the second digit of the code. If the second digit is 3, turn the key to the LOCK position 3 times. Ensure
the key is fully returned to the centre position after each turn of the key.
Enter the third digit of the code. If the third digit is 2, turn the key to the UNLOCK position twice. Ensure the key
Enter the fourth digit of the code. If the fourth digit is 1, turn the key to the LOCK position once. Ensure the key
Finally, turn the key to the UNLOCK position and back to the centre position, a double bleep will indicate that
the code has been entered correctly. A single bleep indicates that the code has been entered incorrectly.
Then, before opening the door, wait 5 minutes for the alarm and immobiliser to be de-activated. During the 5
minute wait for the alarm and immobiliser to be de-activated, the alarm indicator LED in the instrument pack
continues to flash (one flash every 2 seconds).
DO NOT OPEN THE DOOR OR ATTEMPT TO ENTER THE
CAR
until the full delay period has elapsed.
When the 5 minute wait has elapsed, the alarm indicator LED stops flashing. Immediately open the door, insert
the key in the ignition switch and turn the switch to position II. If the ignition switch is not turned to position II
within 30 seconds of the end of the 5 minute wait, the engine is automatically immobilised again.
The EKA code will not be recognised if there is an interval of 10 seconds or more between key turns or if the key is
held turned for 5 seconds or more during the procedure.
In some system configurations a successful EKA code entry is indicated by the audible warning device pulsing twice
for a period of 50 ms on, 200 ms off. The theft deterrent LED is switched on for 1 second, all doors unlock, the alarm
disarms and the vehicle is remobilised allowing the engine to start.
If an incorrect code is entered, an audible warning is emitted and the procedure must be repeated. Up to a maximum
of 10 attempts to enter the code is possible. After 10 attempts, the BCU will not allow any further codes to be entered
for a period of 10 minutes.
Single point entry
Single point entry (SPE) allows the driver to unlock the driver's door while leaving all other doors locked.
There are two configurations for single point entry:
l
SPE not active.
l
SPE active.
To use SPE, press the unlock button on the handset once. Depressing the unlock button a second time in the space
of one minute unlocks the remaining doors. SPE is also possible by turning the key in the driver's door lock to the
unlock position once. Turning the key to the unlock position again within one minute unlocks the remaining doors.
In order for SPE to operate, the following conditions must be met:
l
The ignition is off.
l All doors are locked.
bulletsnbait
Mar 20, 2022 06:30 PM
CRB357
May 12, 2015 07:15 PM
Roverman7
May 19, 2013 08:42 PM
southfloridadiscoII
Jul 18, 2011 07:41 AM
Gulfviews14
Jun 21, 2008 05:45 PM
