Sponsored by: CARiD
99 Discovery II Cold Hesitation
Old Oct 28, 2007 | 09:50 PM
kkuenzel's Avatar
4th Gear
Default 99 Discovery II Cold Hesitation
I am a Lincoln Mercury Tech working on my buddy's Discovery II for a hesitation when cold or a restart after it has sat for a while.
It usually only does it for a very short period of time and clears up within a quarter mile or less. After that,it runs fine.
My buddy says it started about a month ago and had been running fine since I worked on it earlier this summer. I did some routine maintenance
such as replace the spark plugs,oil change,air filter,BG Fuel system service (injector clean and 44k in fuel tank) andreplaced plug wires
When I start it cold,it fires up fine,idles up ok,but when i put into gear and hit the gas,it hesitates almost to the point of stalling and it backfires
through the intake. I know it is running lean,but can't seem to fine a reason for it.
I pulled DTCs from the vehicle,P0171,P0174 (lean banks 1&2) and several misfire and catalyst damage warning codes.
Fuel pressure is 50 psi and holds steady after shut down. checked Coolant and Air Temp PID values and they were normal.also checkedfor vacuum leaks and leaks in between throttle body and MAF sensor
I visually inspected MAF hotwire and cleaned oil residue off with a q-tip and rubbing alcohol,problem is still there.
The Vehicle has 128,000 miles on it.
I have read several posts of people saying that the MAF sensors are troublesome,but have no way of testing one to condem it as faulty.
Any help would be great! Thanks
[IMG]local://upfiles/8340/0F577B843C044DBF8328B37C1EA8F03E.jpg[/IMG]
Old Oct 29, 2007 | 08:09 AM
Default RE: 99 Discovery II Cold Hesitation
First thing, the Bosch MAF's won't take to being cleaned, they'll just up and die on you.
Did you have any code related to either 3rd. or 4th. gear out of ratio. If you did along with both banks running lean, then you will need a MAF, make sure to order it on line, $130, as apposed to doing to the dealer, near $200.
What brand of plugs, what gap and what brand of plug wires did you install?
Old Oct 29, 2007 | 11:34 AM
kkuenzel's Avatar
4th Gear
As a matter of fact,I did have an incorrect ratio for 4th gear code
(P0734)
I installed Bosch Platinum +4 plugs ,no gap adjustment required
Plug wires Im not sure,except they were blue
Thanks, Karl Kuenzel
Old Oct 29, 2007 | 01:03 PM
So you need a MAF, best price around is thru Tony at Cerrone's, 650-365-4145 at around $130 and postage. They are pretty much plug and play and that truck will run fine again. Tell Tony, Mike said Hi.
Old Oct 29, 2007 | 08:49 PM
kkuenzel's Avatar
4th Gear
Awesome,Thanks for all your help Mike. Actually,my son works at the Toyota-Jaguar dealership which is also Engle Imports
Parts. From what he tells me, they are a major parts distributer of British car parts here in Kalamazoo. I'll have him check on price and availability on a MAF sensor.
BTW. Does the Discovery have learned adaptive strategy for fuel trim,if so,will disconnecting the PCM clear it?
Thanks again Karl Kuenzel
Old Oct 30, 2007 | 10:24 AM
Two thought, you will need to clear the codes with your scanner and yes you can re educate your ECU, just drop the negative battery cable for a couple hours and you are set.
Old Nov 2, 2007 | 07:42 PM
kkuenzel's Avatar
4th Gear
Hi Mike! Got the MAF sensor yesterday and installed it.What a difference! runs great cold now with no hesitation or backfire and now it will shift up
to 4th gear. Thanks a Million! Karl
Old Nov 3, 2007 | 06:44 AM
Glad it worked out for you.
LeakyDisco
Nov 15, 2018 05:00 PM
BluePointDisco
Jul 11, 2017 11:44 PM
lovetheyz
May 29, 2014 12:51 AM
pkppunk
Jan 26, 2013 07:05 PM
Disco Fuego
Mar 10, 2009 11:54 AM
