Sponsored by: CARiD
ABS/Brake/TC Lights-Grrr!
Old Nov 14, 2010 | 09:31 AM
puppy's Avatar
5th Gear
Default ABS/Brake/TC Lights-Grrr!
Just got my first Range Rover, it is a 1997 4.6 HSE. When I got it the ABS/Brake/TC light on the dash were stuck on, and only was getting front braking. I pulled and checked all the fuses and relays. Now, when it is running the ABS, and Brake light immediately come on, then the brake light goes out. After a few seconds the Brake light comes back on, with an error message of "low brake fluid", and I get an "ABS fault" error message in my dispaly panel. The brake fluid is not low. But, still only getting the front brakes, no rear brakes, I can tell this by the rust on the back rotors, and the extremely hard braking. Any clues? I would really like to resolve this issue myself. Am wondering if there is any way to test the ABS pump? Any other things I can check, or look for? I would really appreciate any help.
Old Nov 14, 2010 | 10:39 AM
No since trying to guess, go have a good Rover tech, not the dealer run the codes and see what is wrong.
Let us know what you hear.
Old Nov 14, 2010 | 12:23 PM
puppy's Avatar
5th Gear
I agree with taking it to the tech guy. I like to try and figure things out myself, however, am pretty much at the end of what I can do here. One thing I did check, is there is voltage going to the main red/black wiring on the pump. Is there another sensor somewhere that tells the pump to "turn on"? As the pump doesn't seem to be pumping, even with voltage.
Old Nov 14, 2010 | 01:13 PM
hilltoppersx's Avatar
not sure what happened 2 my post. but i posted a link to the RSW Solutions website which has the ABS amigo for your truck that can help you diganose the code for yourself.
Old Nov 14, 2010 | 02:36 PM
puppy's Avatar
5th Gear
Well, after searching threads a little more, I have discovered my ABS pump isn't pumping. It gets power, the wiring, sensors, etc., are good, but, no juice in the pump. I removed the black plastic cover where the wires go in, and did confirm that the pump is getting voltage. So, guess I better find an ABS pump, or figure out how to rebuild mine. I saw a web site that had a breakdown on it, so may look into that. Else, will have to buy a pump,
Old Nov 16, 2010 | 01:20 PM
puppy's Avatar
5th Gear
PROBLEM SOLVED: After isolating the problem to the ABS pump, I replaced it, and now all the brakes work great. Thanks for all the input.
Alan Phillips
Nov 19, 2018 03:27 PM
lipadj46
Feb 8, 2016 08:29 PM
TopGun
Sep 1, 2014 01:11 PM
jamestfl
May 28, 2014 09:52 AM
Bob2003Discovery
Dec 13, 2006 11:42 PM
