ABS Light On
on
RE: ABS Light On
For the most part you don't trouble shoot it, let a mechanic with the appropriate scanner go into the ECU and read the ABS fault codes, then decide how to handle it. Depending on what code they find, the light can mean anything from your ABS is down for any of a number of parts failures to you could loose your brakes. So don't wait around to have a mechanic check it out.
marlymarl
05-28-2011 10:34 PM
Second2None
12-06-2010 05:26 PM
johnkbl
01-13-2009 08:54 PM
Surfin Elvis
06-23-2005 11:08 PM
