Sponsored by: CARiD
ABS Light On
Old Oct 27, 2007 | 03:59 AM
umoms's Avatar
Default ABS Light On
What does it mean that the ABS light is on and how do I troubleshoot?
1996 Land Rover Discovery SD 88k miles Automatic Transmission
Old Oct 27, 2007 | 08:19 AM
Default RE: ABS Light On
For the most part you don't trouble shoot it, let a mechanic with the appropriate scanner go into the ECU and read the ABS fault codes, then decide how to handle it. Depending on what code they find, the light can mean anything from your ABS is down for any of a number of parts failures to you could loose your brakes. So don't wait around to have a mechanic check it out.
Old Oct 27, 2007 | 10:02 AM
umoms's Avatar
Does anyone have a link to a owners manual or guide to a fuse box for a 1996 Land Rover Discovery SD
Old Oct 27, 2007 | 10:13 AM
There should be a directory inside your fuse block cover showing what fuses go where.
Old Nov 6, 2007 | 12:46 PM
umoms's Avatar
Im sorry it was the AWD drive light. How do I pop the fuse for it? Im tired of looking at it. I dont see it in the fuse manual.
Old Nov 6, 2007 | 03:29 PM
Don't pop the fuse, get your t/case out of High Lock before your damage it.
Old Nov 6, 2007 | 10:39 PM
umoms's Avatar
im sorry. Can you explain what you mean? What will popping the fuse do?
Old Nov 7, 2007 | 07:44 AM
If you have a warning light on indicating that your t/case is in a locked position, you are doing damage driving it on the road, why try and hide that by pulling a fuse? Have you tried shifting back and forth between high lock and high to turn your light off?
Old Nov 7, 2007 | 08:36 AM
Landzu's Avatar
Pull the four wheel drive shifter to unlock high this will
get you out of four locked and the light should go out.
marlymarl
May 28, 2011 10:34 PM
Brad S1
Oct 26, 2006 08:53 PM
Surfin Elvis
Jun 23, 2005 11:08 PM
