Sponsored by: CARiD
abs wheel speed sensor prices?
Old Mar 29, 2017 | 10:14 AM
ldenney's Avatar
Default abs wheel speed sensor prices?
hello i need to replace a rear abs wheel speed sensor and the prices range from $40 to $175 ? some of the cheaper ones say they are oem (wabco) brand? has anyone used a cheaper priced sensor? or do i need to buy from somewhere like atlantic british? btw i need the long wire version it looks likesomeone has already replaced it all the way to the slabs btw i am getting right rear output too low and right rear erratic signal i have checked hub it has no play and seems good i also pulled and cleaned sensor my scanner is a icarsoft lr2 thanks
Old Mar 29, 2017 | 09:14 PM
ldenney's Avatar
anyone?
Old Mar 30, 2017 | 07:47 AM
OverRover's Avatar
Order away, and get back to Happy Town ! > SSW500030 > https://www.lucky8llc.com/products/abs-sensor-kit-3
Old Mar 30, 2017 | 03:00 PM
ldenney's Avatar
ok cool thanks but im still wondering why this same part is so much more $$ from other sellers its like $165 at atlantic british
Old Mar 30, 2017 | 06:26 PM
LR Techniker's Avatar
Wabco is the OE supplier to Land Rover for this part. Finding a Wabco for under $100 is highly suspect. Wholesale price on that part is $151. If you get a genuine Wabco, it will be the same part as if you bought it from the dealer, sans any Land Rover markings.
As for aftermarket, its hit or miss. I have had brand new "other brand" sensors not work right out of the box only the fix the issue with a factory brand sensor.
Old Mar 31, 2017 | 10:27 AM
ldenney's Avatar
ok thanks good info
Old Apr 11, 2017 | 12:32 AM
ldenney's Avatar
Hello again just to wrap this up I bought a new sensor from lucky8 and ran it straight to the slabs unit no more lights and everything is working. Thanks
mirepoixmatt
Feb 6, 2016 08:14 PM
RANDY04D2
May 29, 2012 10:13 AM
twaszak
Jun 4, 2011 07:49 AM
acegt1
Jun 3, 2008 12:56 PM
Switzer
May 31, 2008 09:58 AM
