AC air flow issues from the front vent
Hello
I am facing a unusual problem with a massive drop in the air flow from the front vents , ever since I replaced the original AC compressor on my 2008 LR3, a year ago.
the cooling also takes much longer than it used to and I feel that the efficiency of the AC system has reduced drastically.
the blower motor appears to be working fine , as the air flow marginally increases with each turn on the fan dial on the dash.
has any one in this group faced a similar issue ? Any ideas of what could be causing such a problem, would be welcome
bcolins
Jan 27, 2022 08:46 PM
