Sponsored by: CARiD
ACE leak
Old May 6, 2009 | 08:37 AM
ifotophan's Avatar
3rd Gear
Default ACE leak
Hello all -
Recently found a fluid leak coming from the lower ACE hose from the fluid reservoir (2001 Disco II). ACE fluid in reservoir is low - no leak from power steering side. I'm thinking the fix is a simple hose replacement but wanted to ask for recommendations first.
Also - what the best fluid to refill the ACE system?
Thanks!
Old May 6, 2009 | 10:52 AM
Sounds like the return line or it's clamp need replacing.
You should flush the system to improve it's performance. If interested in what to do, PM me your tele number and I'll call you.
Old May 6, 2009 | 10:58 AM
ifotophan's Avatar
3rd Gear
Definitely the hose - used a mirror/light and barely flexed the hose near the first bend from the reservoir and fluid came out clear as day. Already on order.
Old May 7, 2009 | 07:07 PM
matthew527's Avatar
5th Gear
Default oil leak underneath
I have a 99 RR now. Just had oil pan leak fixed two years ago. now Im seeing oil leaks underneath and onto my garage.A mechanic said could be due to oil pressure distribution switch which he says need replaced. Im not sure if it is that though. I am not a mechanic but just having fan driving this car.
Old May 7, 2009 | 07:42 PM
What does this have to do with an ACE, go post on the RR section if you want help.
Old May 8, 2009 | 02:06 AM
KarenCaren's Avatar
You might want to clean it first before replacing the hose. Also I think its still best to you the fluid you already using.
______________
If you ain't first your last!
egr valve
Old May 8, 2009 | 10:15 PM
matthew527's Avatar
5th Gear
sorry I gouffed again you're talking about leaks so I thought I have leaks on my RR too I did know there is a RR forum I just learned about that so off I go to it.
Old May 9, 2009 | 08:23 AM
ifotophan's Avatar
3rd Gear
@Karen - Already changed the hose and flushed the system. The original hose had an inch long crack near the first bend. ACE system working great.
Tin_Man
Apr 12, 2014 11:12 AM
thehrdway
Apr 26, 2011 01:41 PM
tbuckt007
Apr 13, 2010 11:46 AM
johndixon1967
Oct 8, 2009 04:22 PM
alrd
Nov 17, 2006 11:25 AM
