Is it the actuator?
Hi Guys,
This is my first post and I'm doing so after reading through the various old posts on this subject. I read through them all and I'm still left with my question, so here goes.
I just bought an '03 Disco which I purchased with a non-working driver side front door lock. There is no response when I use the automatic locks. All the other doors work fine (including the rear cargo door), which leads me to think that the actuator is the issue. That said, when I put the key into the tumbler it moves freely - too freely really - it just spun freely as if it wasn't connected to anything.
I pulled the door panel off, and although the actuator does appear to be bad, I don't see any linkage or anything going from the door handle to the actuator. Should there be something there? When I pulled the panel the plastic sheeting was still on, so it seems as though I'm the first person to pull the panel. I don't see any broken linkage rods or anything, but I'm not sure what it's supposed to look like. I'd appreciate any help before buying any parts.
Thanks Guys!
Eric
Thanks Guys!
Eric
