Sponsored by: CARiD
Air Suspension Fault-Imagine That!! LOL
Old Apr 18, 2017 | 08:54 PM
CBRover's Avatar
Default Air Suspension Fault-Imagine That!! LOL
2005 LR3 Here. Figuring I need a new compressor. Throwing the good old suspension fault/ Normal ride height only warning that is luckily still yellow at this point. Like the idea of the updated style made by Arnott instead of the old style. Problem is, after installation, it's gotta be reflashed. Will it work at all to pump up enough to drive it to the dealer to get said reflash, or am I looking at a tow bill. And does anyone know if the dealer will reflash one that's not done there?? Any help would be greatly appreciated before she decides to go in perma-squat mode and rip out everything since I've got lift links and over sized tires. 🤘🇺🇸
Old Apr 18, 2017 | 09:47 PM
I want to say it will work just not correctly. Most all dealers will do the reflash and charge you plenty for the privilege
Old Apr 22, 2017 | 08:20 PM
LR Techniker's Avatar
It will work, you will just eventually get an "exhaust valve" fault, but should work enough to pump up the suspension.
revel8or
Jan 15, 2014 06:36 AM
06Range
May 8, 2013 09:01 PM
camaroz1985
Aug 20, 2009 12:26 PM
anhernandez
Aug 18, 2009 12:47 AM
