Sponsored by: CARiD
Alarm intermittently honks car horn
Old 08-30-2010 | 12:23 PM
wcwhiz's Avatar
Default Alarm intermittently honks car horn
I have been told that the alarm module in the 2004 models is built into the body position module. Any idea how hard to change. Im unsure exactly where it is located. ??
And does it have to be reprorammed to the car or is it just plug and play??
Any help appreciated
Old 08-30-2010 | 12:29 PM
hilltoppersx's Avatar
should honk if a door is ajar. that is the obvious question...
Old 08-30-2010 | 03:15 PM
Give us more information, when does it honk, is the truck locked, is it super locked and are any windows/ sun roof open?
Old 08-31-2010 | 07:15 AM
Rovin4life's Avatar
dont forget the hood. If the hood is shut properly and in a stiff breeze it will go off.
and if it does go off it might be the switches.
Old 09-01-2010 | 08:32 AM
wcwhiz's Avatar
Smile alarm problem
I believe it is one of the door sensors the only problem is to diagnose which one it is?? Nearest land rover dealer is 60 miles away.
Old 09-01-2010 | 09:05 AM
Last place you should go is the dealer, they will try and sell you some new doors to fix a switch problem. Try and find a local shop that has some Rover experience.
Old 09-01-2010 | 09:55 AM
where are you located?
Old 09-01-2010 | 11:48 AM
yloDiscoII's Avatar
I find I have an issue with the back gate. Over time it has sagged on the hinges just enough where I have to slam it to shut it properly, so as not to get the "honk"
Old 09-01-2010 | 12:12 PM
If you are having a tail gate alignment issue, go get it fixed before it gets worse and really costs you some big $'s.
Old 09-01-2010 | 01:54 PM
yloDiscoII's Avatar
Thanks for the heads-up Mike. It's been one of those nagging problems I keep neglecting to look in to.
Is there an easy fix? New bushings on the hinges? right now it is pretty difficult to open and close without exerting quite a bit of force. My wife has a helluva time even getting it to swing out all of the way.
(sorry to hijack your thread a little bit whiz)
caymandrew
06-08-2015 11:16 PM
lipadj46
08-13-2009 08:47 PM
PDXDisco
06-25-2008 06:21 PM
willstevens
12-12-2007 12:41 AM
igriego
06-06-2005 05:54 PM
