Sponsored by: CARiD
Alaska limp mode.
Old Jul 20, 2017 | 01:02 PM
Alaskarover's Avatar
Default Alaska limp mode.
Just got a 2003 Land Rover that is stuck in limp mode. The key won't come out of the ignition untill I disconnect the battery. It looks like a brand new xyz switch I tried to adjust it and the red light just blinked for a second. Battery is getting 14.4 volts running. Nobody too take it to here so I'm on my own help me
Old Jul 20, 2017 | 03:37 PM
No Doubt's Avatar
It could be the transmission ECU under the driver's seat beneath the amplifier, or it could be that you need to take the black cover off of your xyz switch, clean all of its internal electrical contacts, and insure that the microswitches can still be depressed (no overly-worn areas, etc.).
Depending on the model of your xyz switch you may need to drill out rivets to get in there, no big deal.
Old Jul 21, 2017 | 12:20 PM
is there a way to check the exu
Old Jul 21, 2017 | 12:28 PM
No Doubt's Avatar
I would think that the easiest 2 ways to test your transmission ecu would be:
#1: put your transmission ecu into a different running, good Discovery to see if it causes the limp home mode there, or
#2: swap in a $22 used transmission ecu from eBay to see if the limp home disappears.
NinjaPlease!
Jul 31, 2019 09:03 AM
cedward
Jan 3, 2011 04:39 PM
Rickey_240
Apr 2, 2010 05:33 PM
vanhorn2dallas
Mar 15, 2010 11:29 PM
xb70valkarye
Feb 2, 2010 10:13 PM
