Sponsored by: CARiD
all four tires wear on inside
Old Jan 12, 2010 | 05:35 PM
mignum's Avatar
3rd Gear
Default all four tires wear on inside
anybody have any ideas on what is causing my tires to wear on the inside?i like to do it myself so if you have some suggestions on a fix let me know.could this be a bushing issue or alignment problem?
Old Jan 13, 2010 | 06:09 AM
Rovin4life's Avatar
alignments have to be performed on alignment machines only.
you won't get it right at all.
too many variables.
besides LR3 Alignments are tricky if the shop doesn't know what they are doing. If they do not let it stay its its standard height while aligning the angles will get screwed up.
as expensive as dealers can be, they will know what to watch out for and to look for any loose parts and how to diag them. Alot of times some parts can look like others causing issues.
I have seen many an aftermarket shop bald LR3 tires because they didnt watch how the vehicle sat when aligning. as the vehicle goes up and down for any reason the camber and toe settings change rapidly.
Sometimes on high mileage LR3s the damn bushings freeze, the bolt stays in and worse of all you have cut the bolts out with a sawzaw. Plus if a alignment camber bolt is stripped the shop will likely have them and put you back on the road quickly. The other shop won't charge you for an alignment and do nothing about the bad angles not telling you until the tires wear.
Old Jan 15, 2010 | 08:38 PM
mignum's Avatar
3rd Gear
Default tire wear
thanks for the tip ill bite the bullet and take it to the dealer just bought new pirelli atr's
smokey73
May 2, 2019 11:20 AM
AKRanger
Sep 26, 2013 01:07 PM
crama12013
Aug 18, 2010 12:30 AM
Disco2Fever
Apr 16, 2010 09:28 AM
rbelz
Feb 28, 2008 04:31 PM
