All 4 tires have worn badly on the inside edges
Old Aug 16, 2010 | 04:11 PM
crama12013's Avatar
5th Gear
Default All 4 tires have worn badly on the inside edges
A few days ago, I noticed that the rear tire on the driver's side of my 2006 LR3 was losing air, also got the handy-dandy low tire exclamation point message on the dash and began receiving a message about a suspension fault with the orange/yellowish warning light on the dash....... I tinkered with putting air in it a day or two but when I woke up this morning the tire was flat as a pancake! Anyway, took it to the tire shop and they fixed it, no problem....... BUT they did say that all 4 of the tires were showing significant wear on the inside of the tire and I am still getting the suspension fault message and warning dash light.......... The hydraulics seem to be working fine but the message and light are still present....... Any ideas, suggestions, causes, clues, etc. Much thanks!
Old Aug 17, 2010 | 10:25 PM
Johnson Rods's Avatar
LR Forum Vendor
Sounds like an alignment issue. I would rotate and balance the tires and take it in for an alignment. It the tires are too worn, replace them and get a new alignment.
Old Aug 18, 2010 | 12:30 AM
geotrash's Avatar
x2 on the alignment. Make sure that if you have an alignment done, it's done at a dealer. The equipment to do it right is very specialized.
Dave
riggskwong41
Dec 4, 2014 10:59 PM
bcolins
Jun 28, 2013 08:28 AM
mignum
Jan 15, 2010 08:38 PM
tads
Aug 27, 2008 04:15 PM
epeteha
Jun 9, 2008 05:27 PM
