Sponsored by: CARiD
Anybody Ever Try This Coolant Filler?
Old Dec 26, 2013 | 03:47 PM
04duxlr's Avatar
Default Anybody Ever Try This Coolant Filler?
This looks like the right tool for Discovery owners:
UVIEW 550500 AirLift II Economy Cooling System Refiller : Amazon.com : Automotive UVIEW 550500 AirLift II Economy Cooling System Refiller : Amazon.com : Automotive
Has anybody tried this? Might be worth the money once you add up the cost of spilled fluid and excessive bleeding effort for a few rounds of coolant flushing.
Old Dec 26, 2013 | 03:58 PM
dusty1's Avatar
interesting. never seen such a piece of kit.
Old Dec 29, 2013 | 12:50 PM
LR Techniker's Avatar
Its an essential tool for any vehicle that is difficult to bleed. I have the Kent-Moore version, but it works the same way. It pulls a vacuum on the entire cooling system, removing air. Then when you open the fill valve, it pulls coolant into the system.
Most cars only need the procedure done once. Hard to bleed vehicles like the Disco, I will use the tool 2-3 times in succession to get all the air out.
Another feature of this tool, is that it helps you validate the repair. If you can't pull and hold a vacuum, then either the repair wasn't successful, or there is another leak in the system. On vehicles like Porsche, where coolant is $30 gallon, I like to know I won't have to open the system back up once filled.
Old Dec 29, 2013 | 01:09 PM
blamo's Avatar
I think I can live without it I bleed from the bleed screw with just a lil bit of pres.on the upper hose. Just a tiny twist & a lil bit of air Over & over untell you don't get any
pwaltrip
Jul 26, 2016 10:00 PM
Gordon Bombay
Dec 25, 2012 04:52 PM
Big Jim Swade
Dec 16, 2011 10:47 PM
RustyHamover
Jun 28, 2011 12:06 AM
ljdiscovery
Aug 21, 2009 10:41 AM
