Sponsored by: CARiD
auto transmission problems 93 RR SWB
Old Mar 18, 2007 | 09:45 PM
cold_surfer's Avatar
Default RE: auto transmission problems 93 RR SWB
what do you think of this tranny pan? gritty junk in there -- I'm guessing clutch parts? Yikes.
No - you don't have to completely remove the Y-pipe and crossmember.... front of Y-pipe, all bolts from crossmember and lower it 3/4 the way. makes a mess...
Old Mar 19, 2007 | 01:13 AM
Okay, so the filter replacement is done. 4 MORE new quarts of dex3 and LUCAS tranny additive. All forward gears work GREAT, no problems, no slipping. However, NO reverse yet -- it does not engage/slip, it's just like neutral.
So more research in the manual....
Does anyone know what Rover means by "reverse gear interlock valve siezed"? The only other reference to it in the rover manual is the "gear selector interlock" and it's electronic -- no "valve" (that implies fluid, not electronics). I've attached the gear interlock portion. There is an inhibitor switch -- is that related?
Thanks,
Tony
all1knew
Jun 5, 2009 12:49 PM
all1knew
Feb 23, 2009 06:14 PM
cold_surfer
Feb 14, 2008 07:36 PM
mad4rovers
Apr 12, 2005 04:09 PM
motorsportinc
Apr 12, 2005 11:26 AM
