Sponsored by: CARiD
Battery's Light Intermittently Goes On
Old Nov 18, 2016 | 03:11 PM
tissocal's Avatar
3rd Gear
Default Battery's Light Intermittently Goes On
My LR3 2005 HSE (90k miles) seems to be fine, but about ten minutes into any drive the red battery light comes on and stays on. They battery is new (5/2015) and car serviced well. I also tested battery and had decent volts:
Engine Off - 12.43v
Engine On - 14.16v
Engine On - with heavy load (pulling more amps from AC, lights and radio on) - 13.6v
Thoughts anyone?
Old Nov 20, 2016 | 10:06 PM
XCELLER8's Avatar
well....it could still be the alternator....or likely the voltage regulator INSIDE the alternator...I just went through this with one of my vehicles
Old Nov 21, 2016 | 08:45 AM
tissocal's Avatar
3rd Gear
Thanks. But if alternator is bad how can the voltage be greater when engine running? Thanks again
Old Nov 21, 2016 | 12:35 PM
mollusc's Avatar
Did you test the relevant fuses and fusible links? I've had some weird things happen when some of those have blown.
Old Nov 21, 2016 | 03:26 PM
tissocal's Avatar
3rd Gear
good idea. I'll do so this weekend and see weekend hat gives
Old Nov 21, 2016 | 10:04 PM
XCELLER8's Avatar
Cool
I wish I could explain it to you...but rather than b/s you ...my 96 D1 did the exact same thing......appeared to be chargng the battery when tested with a voltmeter...but the battery light would flicker and even the lights flicker intermittently...
voltage and watts are 2 different things...think of voltage as "potential" and watts as "power".....I'd better stop there.....lol
fishkilla67
Jul 16, 2016 11:23 AM
Jthroneberry
Jun 21, 2015 01:33 PM
marlymarl
Apr 21, 2012 12:49 PM
mictouch
Nov 13, 2011 08:22 PM
95Discovery
Sep 26, 2007 06:24 PM
