Sponsored by: CARiD
bearings question??
Old May 15, 2015 | 09:29 AM
CATTIVA73's Avatar
Smile bearings question??
My 2007 RR supercharged needs new front bearings..that grinding noise is getting louder and bothersome...:
I was told to replace the bearings ONLY and not the all hub assembly to fix the problem...is this a good idea?
How much time in labor does it require??
Thanks
Old May 15, 2015 | 02:09 PM
justryan's Avatar
Yes that was good advice , because the hub is just the housing for the bearing ,you wont need to change it , the bearings/race may will need to be pressed out by a machine shop ..
the reason people change the complete thing is because ,the salvage ( used parts ) yards sell the complete assembly just to bolt on with the bearings and all , BUT !!! it a gamble because it could be just as bad as yours.. unless it from a RR that you know the history of.
But you should act on it , because if the bearing shells out ( breaks up ) it will cause more damage in the long run .
Old May 15, 2015 | 04:13 PM
CATTIVA73's Avatar
Thank you.
rambo
Engine & Internal
Feb 22, 2014 06:45 AM
bklahl
Oct 10, 2006 03:11 PM
sanmigmike
Aug 24, 2006 03:37 PM
rambo
May 17, 2006 08:02 PM
rambo
May 10, 2006 04:10 PM
