Sponsored by: CARiD
Brake drag
Old Jun 3, 2015 | 05:32 PM
  #21
winx's Avatar
There is play btwn pushrod and brake pedal. Don't see a way to adjust on my model
Old Jun 3, 2015 | 06:40 PM
  #22
Merlin390's Avatar
Default Booster
The two bolts or nuts that hold the master cylinder to the booster. Take them off. If you gently move the master cylinder to the side you can access the rod. When you take the master cylinder loose line it up like you're going to reinstall it to the booster. If you have to use any amount of pressure to make it fully contact the booster then you need to adjust the rod inside the booster.
Old Jun 4, 2015 | 08:53 AM
  #23
winx's Avatar
OK will do. As I remember that rod was solid-the adjustment is with the contact point?
malmberg
Aug 9, 2009 07:57 PM
bmwrovers
Jun 4, 2009 06:17 PM
Disco Alan
May 13, 2009 12:34 PM
Disco2Guy
Jul 19, 2008 02:23 AM
okdiscoguy
Aug 3, 2007 06:16 PM
