Sponsored by: CARiD
Brake light switch; square peg in round hole
Old May 21, 2012 | 02:29 PM
ggray's Avatar
7th Gear
Default Brake light switch; square peg in round hole
1995 D1, manual transmission. I need to replace the brake switch for the second time, and the replacement I got needs a square hole whereas the old switch(s) required a round hole. B-P says all they have are like my new one.
Anyone faced this problem? Solution? I'm going to check NAPA, looking for a miracle as inspection is about to expire.
TIA
Old May 21, 2012 | 03:06 PM
antichrist's Avatar
I think you want a Standard Motor Products SLS-259. NAPA can cross.
I'm not at home or I'd go look at mine for you.
Old May 22, 2012 | 01:02 PM
ggray's Avatar
7th Gear
Thanks Tom, but that part is just like what I got. Fits a square hole, and the hole in my Disco is round.
If it weren't in such an awkward spot, I'd file it to make this switch fit.
Old May 22, 2012 | 02:17 PM
antichrist's Avatar
I just went out and looked at mine. It's a Hella, try PN: 6DD 008 622-521
Old May 24, 2012 | 12:53 PM
ggray's Avatar
7th Gear
Looked under the dash with a flashlight to see how difficult it would be to grind the round hole square, and lo and behold, I saw additional holes in the bracket above the one in which the old switch was mounted.
One was square! The switch I received (and looks like SLS-259 that Tom mentioned) fit right in.
Live and learn.
Old May 24, 2012 | 01:50 PM
antichrist's Avatar
Ha. Sounds like you ran in to a SPOT, Stupid Previous Owner Trick.
Old Aug 9, 2013 | 05:03 AM
ggray's Avatar
7th Gear
No, the hole has been there from the factory.
I AM the SPO!
Old Aug 9, 2013 | 09:36 AM
fishEH's Avatar
The round hole is the Cruise Control switch.
JPSpen
Jan 23, 2013 07:08 PM
me 2
Nov 15, 2012 07:15 PM
Savannah Buzz
Apr 1, 2012 12:26 PM
audiS4S6
May 6, 2010 12:14 PM
grussell
Aug 23, 2009 09:33 PM
