Sponsored by: CARiD
brake servo line/hose
Old Oct 23, 2013 | 07:40 AM
elkinspd's Avatar
4th Gear
Default brake servo line/hose
I recently broke the tip of the hose and the adapter connecting the hose to the manifold, so I bought another line and adapter. My question is how do I pull the existing line from the brake servo? Do I just pull it out? I did apply a little pressure where as to pull it out and noticed that air was either coming out or being sucked in.
Old Oct 23, 2013 | 09:22 AM
drowssap's Avatar
did you get just the hose or is there a check valve on the end?
Do I just pull it out? yes
Old Oct 23, 2013 | 09:41 AM
elkinspd's Avatar
4th Gear
Default brake servo
There is a check valve on the end.
Old Oct 23, 2013 | 12:26 PM
drowssap's Avatar
pull one out and install the other; just let the truck idle before you jump in it do drive. you will have lost all the vacuum assist until it builds back up.
Old Oct 23, 2013 | 03:51 PM
elkinspd's Avatar
4th Gear
Going to give it a try now. thanks
me6067
Jun 26, 2015 12:10 PM
01d2Jeff
Feb 1, 2012 08:04 PM
TNdisco
Dec 12, 2010 10:09 AM
jlgolson
Jan 17, 2010 12:31 PM
salve7
Nov 23, 2009 01:00 PM
