A/C compressor is sticking sometimes?
Now another issue I have is with my AC compressor. When I turn it on sometimes I have the raise the hood and tap the clutch to make it engage. Also the blower fan relays keep "burning" out, and don't seem to allow for enough power for the fans to blow properly. Any ideas on this issue. Thanks.
Relays "burning out" usually mean fried contacts. Usually from too much current. Usually from fan motors staring to lock up, or same with AC compressor. Volt meter will tell you if 12 volts plus at the motors or the compressor clutch.
Now if only we knew which year and model of truck you had we could look at the RAVE electrical drawings and find connectors and ground points to check. But you can look that up in your copy.
lead.sled.fan
07-22-2010 08:01 AM
