Sponsored by: CARiD
Cam shaft question
Old Apr 14, 2021 | 09:42 PM
Bennyboy's Avatar
Default Cam shaft question
Hello good fellas!! So I am replacing the front crankshaft seal on my 2000 Land Rover Discovery II
I didn't realize I needed a tool or something to lock it in place. I turned it quite a few times both ways trying to get the bolt lossened
My question is
1. did I mess anything up?
and
2. when I after I change it do I have to line up rhe crankshaft or anything? Get it sitting right with the timing belt an stuff?
Thanks guys!
Old Apr 15, 2021 | 02:44 PM
Harvlr's Avatar
You haven’t wrecked anything, all you’ve done is turn the crankshaft. There are posts in the D2 section on guys putting their wrench on the crankshaft pulley nut and bumping the starter. I made a tool to hold it, quite a simple tool really, and it seems to me a lot safer. When you reinstall the pulley you need to line up the slot in the pulley with a woodruff key on the shaft
Old Apr 15, 2021 | 06:18 PM
mollusc's Avatar
Pretty sure the RAVE manual contains all the info you need to set the camshaft in the correct position and ensure that everything is timed correctly.
ForTex
Jun 3, 2016 09:41 PM
Idioteque2
Nov 23, 2015 05:59 PM
MrFlea
Sep 7, 2011 02:22 PM
mrg
Feb 8, 2011 07:51 AM
disco2adam
Nov 10, 2007 11:02 AM
