Sponsored by: CARiD
Can anyone bypass and make manual ignition
Old Jun 13, 2025 | 12:54 PM
earlbuller's Avatar
3rd Gear
Default Can anyone bypass and make manual ignition
2004 land rover discovery. Will crank but no start. Obsolete so needs to be programmed or bypassed. No help from dealers or mechanics local. Appreciate your help.
Old Jun 14, 2025 | 09:35 AM
mollusc's Avatar
You should post questions about the Discovery 2 in the appropriate forum.
If you are able to turn the key then you don't need to bypass it. There is no chip in the key so your problem is somewhere else. Either the inertia switch or the crank position sensor are relatively common causes for the situation you are describing.
Old Jun 14, 2025 | 11:31 AM
earlbuller's Avatar
3rd Gear
Default Land rover discovery ignition
I appreciate the input. I will relay to the mechanic.
I'm in North NJ and at the mercy of the elements.
earlbuller
Jun 12, 2025 07:52 PM
nickcashmere
Oct 9, 2023 09:55 AM
Carolina919
Nov 30, 2014 08:36 AM
maybere
Dec 1, 2010 10:15 AM
harchy
Mar 11, 2009 11:03 PM
