Sponsored by: CARiD
CAN ANYONE WALK ME THROUGH A RADIATOR REPLACEMENT?
Old Dec 29, 2007 | 07:01 PM
brianex's Avatar
Default CAN ANYONE WALK ME THROUGH A RADIATOR REPLACEMENT?
'03 Disco II, 75K. I just spent $1951.28 at the dealership Thursday getting new plugs and wires and, yes, the "updated ABS Modulator kit and updated ABS electrical wiring" (at least there aren't any more lights on my dash......I guess). Anyway, so I knew before I went in that I was gonna need a new radiator because I JB welded a hairline crack in mine like two weeks ago (it's still holding ). Anyway, dealer wanted $980.00 to get the job done, including the radiator, but I was thinking that it wouldn't be so hard so I have one on order and it'll be here this week..... I also need to replace my Throttle Heater Plate Gasket while I'm at it (know that's gonna be easy), but Iam wondering if there's anyone out there who can guide me through all this - I AM OUT,OUT,OUT,OUT of money at this point so I'm gonna HAVE to have a go at this stuff on my own.[:'(]
Old Dec 29, 2007 | 07:55 PM
N.Franklin's Avatar
Default RE: CAN ANYONE WALK ME THROUGH A RADIATOR REPLACEMENT?
Get your radiator from www.performanceradiator.com, takes about 2 hours max. Two brackets on top, 4 oil lines to disconnect, remove the fan and shroud first and make sure its drained. When I did mine I changed out the hoses, clamps, fan clutch, and water pump; not a cooling issue since.
Old Dec 29, 2007 | 08:37 PM
sideburns's Avatar
pull the battery and battery tray,pull the air box assy,remove top shroud,fan, bottom shroud remove the side brackets that secure radiator to header remove top and bottom rad hoses, unscrew trans and engine coolers from rad ,leave cooler line attached, pull rad up and out,reverse to reinstall,have fun and take it slow... not a big deal
Old Dec 30, 2007 | 12:08 AM
brianex's Avatar
Okay, Okay, sounds simple enough - as I thought it might. Thanks A TON! I'm kind of excited to do it actually. I recently replaced all of the hoses and stuff myself (less than amonth ago - I thought that the upper hose was leaking....turned out to be the rad itself) so I plan on reusing them obviously. Do I fill the radiator in the same way I did when I replaced the hoses? Just keepslowly pouring it into the reserve tank until coolant starts coming out of the bleeder screw, start it, check it, etc......?
Old Dec 31, 2007 | 11:19 AM
brianex's Avatar
Just a quick update: Today I went down to the dealership and spent 24.00 on a kit for the Throttle Heater Plate. It took me about 45 minutes or so to get the job done and the newly designed plate is supposed to be much better! It was a peice of cake - really! I'll post back again when I recieve my new radiator....
Old Jan 5, 2008 | 01:53 PM
lrobin3w's Avatar
D-2 radiators are not as simple to replace as you might think! however there is a trick, no cooler lines or airbox removal required. just 2 hidden screws. If you havent already figured this out, I can help.
Old Jan 9, 2008 | 09:01 AM
brianex's Avatar
Two hidden screws? WHERE?!
Old Jan 9, 2008 | 08:08 PM
lrobin3w's Avatar
Ok after removing the radiator fan, shroud and hoses, you will need to remove the two plastic brackets on either side of the radiator. there are two largesilver phillips screws at the top of rad facing forward, remove, nowusing a long phillips head screwdriver go in from the front of the grille, about halfway down and push the large rubber covers outward exposing the hidden screws 1 at either end. remove these and push the rad back from the top seperating it from the brackets. now you can access the screws holding the oil coolersonto the front of the radiator remove them, and slide radiator out. As I said it is not easy, but you will save about $300+ in labor at the dealer
Old Jan 12, 2008 | 01:50 AM
brianex's Avatar
LISTEN TO THIS!!!!! Got my radiator in the other day - finally! I used everyone's advise, along with the RAVE directions and removed my old radiator. Besides removing the cooler lines themselves (that was tough, my fingers are raw and my kuckles are all scraped up), piece of cake. Anyway, I installed the new radiator with EASE, put everything back together and start fillin' her up.................only to find that the NEW radiator leaks like there's no tomorrow. It was BRAND NEW! Long story short, after removing the old, installing the new, removing the new, and installing the old, I'm practically a professional at installing and uninstalling DiscoII radiators - The old one is back in the Rover, leaking as usual,and I've shipped back the faulty radiator and don't look at all forward to installing the replacement when it arrives next week-though I'llDEFINITELY know what I'm doing!
redriderrick
Jun 28, 2014 11:03 PM
Marni
Jul 12, 2013 02:00 PM
phil29
Jun 3, 2011 11:42 AM
Chrisinhouston
Mar 31, 2010 11:07 PM
demobud
Sep 24, 2007 07:04 PM
