Sponsored by: CARiD
Can I change only the Drag linkage ends.
Old Feb 18, 2013 | 02:42 PM
dirklemond's Avatar
Default Can I change only the Drag linkage ends.
I have a 1997 RR, went to have a front end alignment and was told that my drag linkage need to be replaced first. It is not bent, the end on the passengerside is worn and loose(wobblie). I wanted to know if I could just change the drag linkage ends instead of the entire bar? Thanks in advance for any advise or help you can offer.
Old Feb 18, 2013 | 05:12 PM
Rovin4life's Avatar
Depends, the part that has the adjustment on it, you can' the other part that is crimped. No you can not.
Most of the time they are seized on and need to be heated out.
MuleyJ
Aug 15, 2012 11:33 PM
collin Barrows
Aug 28, 2011 07:13 AM
bmwrovers
Jun 4, 2009 06:17 PM
okdiscoguy
Aug 3, 2007 06:16 PM
