Sponsored by: CARiD
Car wash killed 97 Disco
Old Apr 29, 2006 | 02:46 PM
dacoach1428's Avatar
3rd Gear
Default Car wash killed 97 Disco
My son ran his 97 Disco thru an automatic carwash and it died in the middle of the wash. now it will turn over but won't start any ideas on what might have happened? thanks for the help.
Old Apr 30, 2006 | 01:41 PM
Default RE: Car wash killed 97 Disco
That is a hard one to answer with out going thru and checking. You don't have a distributor to get wet, which is good. Have you checked to see if there is any spark, any fuel pressure?
I was my engine at the car was every 2 weeks with high pressure and never had a problem.
Does it turn over at it's usual speed, does it sound like it wants to start??
Mike
Old May 1, 2006 | 03:31 AM
mikemeyer0's Avatar
water in computer....? check there seen this 3 times
Old May 3, 2006 | 12:10 AM
3rd Gear
Well, It wasn't anyhting to do with the carwash, it seems it was just the fuel pumps time to go. i did replace the pump with much cheaper GM style pump. $67.00 vs. 400+ from the Dealer. It was a simple change and everything was a perfect fit. The part number for the pump was Master or Airtex brands E3240, NAPA P70046. just replace the pump only with out all housing, float etc.
Thanks for helping out a newbie.
Old May 3, 2006 | 12:43 AM
mikemeyer0's Avatar
ORIGINAL: dacoach1428
where did you hear about the fuel cheaper pump....
Old May 8, 2006 | 10:44 AM
3rd Gear
I just did a google search for land rover fuel pumps and there was a couple of sights describing the change. the only thing I had to do different was put a hose clamp on the fuel line. The original plastic line got stretched when trying to get it off. The website noted that you may have to change the wiring but mine was a wired the same. Good luck.
Scott R
Jan 6, 2010 11:23 AM
VFib-911
Nov 10, 2009 02:41 AM
kayaku
Jan 18, 2009 10:24 AM
bobbydave
May 14, 2008 08:52 PM
JRdisco1
Dec 22, 2005 12:37 AM
