Sponsored by: CARiD
CDL/transfer case slow process install in 03 disco
Old Aug 4, 2014 | 03:38 PM
Tyberiusz's Avatar
Default CDL/transfer case slow process install in 03 disco
Hello to all
I'm in a slow process, or I should call it "a journey" of installing LT230 (180 K miles on it) out of 99 disco 2 to my 03 disco. I already pulled it out of a donor vehicle, have it washed and waiting for necessary maintenance.
I noticed an oil leak by the hand brake drum. That gives me one seal to be replaced. Since I have it down on the table are there any other things which potentially need my attention? Do all seals right on the spot? What would be your suggestions?
Thank you in advance for words of wisdom.
Adam
Old Aug 5, 2014 | 07:22 AM
drowssap's Avatar
@ 180k, I think I would consider replace any of the seals that could be done easily.
Old Aug 5, 2014 | 12:54 PM
Paul Grant's Avatar
Why not just remove the front output assembly from the high mileage '99 LT230, clean it up with a new output seal and slap it on the '03 transfer case already in your truck. They you have the nipple, can install the shift linkage and viola! you have a CDL.
It's a whole lot easier and a lot less work than dropping the transfer case out and swapping in another, high mileage unit.
Old Aug 6, 2014 | 08:38 PM
Tyberiusz's Avatar
Paul
You just gave me best idea to speed up my project. Thank You so very much. It has never popped out in my head that I could do only a partial swap. Once I get the replacement seal off I go to finish it up.
Adam
BrandonS
Jan 6, 2015 09:30 AM
lmcgrew79
Nov 19, 2013 11:20 PM
Jared9220
Oct 28, 2012 10:50 AM
Finn Dunn
Aug 10, 2008 06:23 PM
Mr. Krisztian
Nov 27, 2007 12:55 AM
