Sponsored by: CARiD
charging problems 97 disco.
Old Oct 24, 2006 | 08:23 AM
sabsr1954's Avatar
Default charging problems 97 disco.
I own a 97 discovery with a charging problem I replaced the battery and alternator but it still wasnt charging where it should be only about 13 volts at idle and less at 2000 rpms so we instaled another alternator and its still the same can any one help! thx.[size=1][/s[IMG][/IMG]
Old Oct 24, 2006 | 12:29 PM
Default RE: charging problems 97 disco.
Have you inspected and cleaned all the connections and grounds? You might want to retest using a tester from one of your local auto parts stores see if there is a difference and also performing a load test.
Mike
Old Oct 24, 2006 | 04:25 PM
geoman's Avatar
As Disco Mike says, have the alternator checked on a test rig at the autoparts store. We have had Bosch re-manufactured alternators that were bad out of the box (actually--two in a row).
regards,
Geoman
www.eurotekapg.com
christians1600
Jun 19, 2009 03:35 AM
charley_bucket
Apr 29, 2009 03:58 PM
steve
Feb 18, 2009 12:02 AM
nce1500
Jul 23, 2008 08:18 AM
maddash6
Jan 13, 2008 08:12 AM
