Sponsored by: CARiD
Check engine light
Old Apr 29, 2008 | 08:39 PM
atmiller's Avatar
3rd Gear
Default Check engine light
Hello everyone
Hopefully somebody can help me out with this. I own a 1996 Disovery and can't get it to pass emmissions. The OBD diagnostics say that there are problems with the O2 sensor heater circuit open upstream, and O2 sensor heater high resistance upstream. I have already reeplaced 2 o2 sensors on the passenger side of the vehicle, but these codes keep coming up. I am hoping someone out there could give me some solid hints on what it actually needs to pass inspection.
Thanks a lot
Old Apr 29, 2008 | 09:07 PM
Default RE: Check engine light
How many miles on your truck?
What are the exact fault codes?
You must replace all 4 02's when doing it.
You will probably find you have either some bad connections or issues with the 02 sensors wiring harness.
Old Apr 30, 2008 | 08:56 AM
atmiller's Avatar
3rd Gear
Thank you Mike, there are 160000 miles on the truck, the codes are p1185 and p1188. Why do all four have to be replaced if two of them were still good. Is it possible that the O2 sensors are no the whole problem and that the problem could have to do with the air/fuel mixture process, like air flow sensors or a bad fuel pump? Plus how can I tell if my cat is toast, I see a lot black soot at the end of my tail pipe. I smell fuel when driving around like it is burning it way to rich, if that helps.
Plus my SRS light won't stop flashing, ever had to fix that before?
Thanks
Old Apr 30, 2008 | 09:03 AM
I understand you concern about your 02's, but bottom line after they hit 100K, they are not giving your engine the full range of their ability, hence you are getting less performance and worse gas mileage compared to a new set.
Change them and see. By the way, it is not your fuel pump, and as for your SRS, I would go have some check it for codes cause it has failed on you, as the fault codes will show.
Old Apr 30, 2008 | 11:20 AM
atmiller's Avatar
3rd Gear
Thanks, besides the o2 sensors what would cause the disco to have a rich air/fuel mixture, becasue the tailpipe is very sooty and is running very rich.
Old Apr 30, 2008 | 01:10 PM
Bad readings from the 02's to the ECU, most likely.
What octane gas are you running?
I would suggest high test, you will get better mileage and less change of a carbon build up.
When you get this taken care of consider an engine flush then an induction cleaning to get rid of alot of old sludge and carbon.
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
