Sponsored by: CARiD
Check Engine Light?
Old Oct 26, 2005 | 06:52 PM
rpatton's Avatar
6th Gear
Default Check Engine Light?
Hey any help here would be appreciated. 92 Range Rover, 88,000 miles. Before I take it to the shop is there anything that I could do myself to fix the check engine light? Anyone have any ideas on what it could be?
Thanks.
Old Oct 28, 2005 | 09:32 AM
Rovercountry's Avatar
4wd High
Default RE: Check Engine Light?
Check all your connections on the top and sides of the engine to any sensor. Any fluid in these connections will cause the light to come on. It's an easy check and fixes it about 25% of the time.
Old Oct 29, 2005 | 12:17 PM
bonnettoboot's Avatar
Buy a generic OBD scanner some are very cheap you will then be able to read trhe fault codes
________
Kawasaki ER-5
Old Oct 29, 2005 | 11:53 PM
Bait's Avatar
A 92' RR is not OBD, it's Lucas 14CUX.
FlyingZebra34
Feb 22, 2014 05:39 PM
RoverZebra
Dec 8, 2012 04:27 PM
Jeremiahbullrog
Apr 21, 2012 06:17 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
