Sponsored by: CARiD
choking fuel??
Old Dec 18, 2016 | 03:40 PM
burl's Avatar
8th Gear
Default choking fuel??
Hi New here and technically ignorant ! My diesel Disco 1997 jap import when driving and building speed is surging off on off on with power and as speed increases around 90 t0 100 kms per hour seems to settle down to drive ok .
I changed the air flow censor with an old one and it seemed to run ok for half a day then went to it again ?? what are the possibilities to fix this .
many thanks for your ideas
Old Jan 16, 2021 | 09:17 AM
mgbjimmy's Avatar
5th Gear
Default Update
Did a live data check and only note the minor change, no big jump in mph. Disconnected the VSS and the issue continues.
the only other factor that may be relevant is I had removed the purge valve since it wasn't working. I doubt it's an effect as the problem started much after.
mrshare
Sep 18, 2015 06:02 PM
Lord Wert
Jun 5, 2013 11:38 AM
kog50
Sep 20, 2011 01:54 PM
Mchuk22
May 27, 2011 09:32 PM
dchyun
Jun 4, 2006 06:03 AM
