Clicking from under drivers side while driving? HELP???
Thanks all of you for your help with the u joint issue, you guys know these vehicles. I changed them out, and one was really badly worn, the others seemed to be in pretty good shape but I changed them too. And no more chirping or clicking.
Now another issue I have is with my AC compressor. When I turn it on sometimes I have the raise the hood and tap the clutch to make it engage. Also the blower fan relays keep "burning" out, and don't seem to allow for enough power for the fans to blow properly. Any ideas on this issue. Thanks.
Mine didn't have a center ball, mine is a two part drive shaft with a single u joint at each end of the drive shafts. The front one goes from axle to transfer case, and the second goes from torque converter to rear axle. No funky two joint knuckle in there.
The system was charged this spring, that was the first thing I tried. It works sometimes, then other times I have to tap the clutch to get it to engage.
rezzrover
05-07-2013 06:02 PM
RoverLady
04-26-2012 08:56 PM
domyo
09-25-2008 12:19 PM
