Sponsored by: CARiD
code p0012 and misfire code p0307.
Old Oct 26, 2010 | 12:17 PM
hatt53's Avatar
5th Gear
Default code p0012 and misfire code p0307.
the sound is comming from the passanger side valve cover. I read the codes and it is giving the p0012 and p0307. I have replaced the lower timing chain tensioner and I still have a loud ticking noise. The noise gets louder on acceleration and the p0012 and p0307 code came back on.
Could this be caused by the Cam sensor being bad. 2003 Range rover
Thanks for any help or insight in advance
Regards,
Todd
Old Nov 3, 2010 | 07:58 PM
Rovin4life's Avatar
the bmw engines have very little problems. But if you want more info ask the bmw guys. its a 4.4 liter M62 engine. we use the same parts as well.
Old Mar 27, 2013 | 05:16 PM
arijfeli's Avatar
I have the same P0012 code. Any suggestions? I read that the cause might be the VARIABLE CAMSHFT TIMING solenoid (VCT)
rtindle1975
Jun 11, 2014 03:05 PM
Murph2121
Feb 20, 2013 01:00 PM
jimbo972
Jul 14, 2010 09:00 PM
mtat
Oct 2, 2008 10:03 PM
