Coolant Leak
Hi I have a 99 disco I. Sometimes when at idle coolant will blow past coolant bottle cap and leak. Truck never overheats or looses coolant any other time. Has good heat. Happens every couple of months. Doesn't matter if its 100 or 0 outside. sometimes after 5nim of driving or hours. It looses about a half gallon. I shut it of for a couple min than start it back up and no problems. Get home and top it back up with coolant then good to go for a couple months till it happens again. Has anybody ever had this problem before???? Only thing I can notice is the cap is a pain in the *** to get on and off.
re: Truck never overheats
If you depend on the factory temp gauge you won't know until it is too late. It points at 50% from about 130 - 240F. Get a scanner that can read live data like an ultra gauge. Here are two pix that show some of the spread.
I do agree that a new cap is a good first step.
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
aguison
Nov 18, 2012 05:15 PM
lipadj46
Jul 8, 2009 07:41 PM
