Sponsored by: CARiD
Coolant By-pass flow valve -- How It Works Illustration And Why?
Old Jan 14, 2016 | 11:28 PM
number9's Avatar
Default Thermostat Coolant By-Pass Flow Valve -- How It Works Illustration And Why?
Found a simplified illustration while doing research on thermostat options for my D2 and thought it might help others better understand the cooling systems on some of our LRs. Attachment and explanation of why the by-pass came from here: '+'
I reread the description in the D2 WM and found it again to be sketchy at best. The RR 99-02 uses a similar system and WM has a better description IMO.
These LR thermostats control the flow of coolant from radiator to pump. Inline thermostat modification will controls flow of coolant from engine to radiator & does away with the by-pass.
When LR by-pass type thermostat opens it's allowing close to normal temp coolant to flow from radiator. On initial warm-up when the inline thermostat opens cooler than normal coolant will temporarily flow from radiator.
Note: The coloration in bottom illustration of full warm should be all magenta.
Attached Thumbnails Coolant By-pass flow valve -- How It Works Illustration And Why?-thermostat-illustration.gif
TRIARII
Off Topic
18
Jan 27, 2014 12:06 PM
jpmiller
Jan 1, 2013 10:05 AM
DiscoBenjamin
Mar 17, 2011 11:30 PM
aublec22
Jun 10, 2009 05:25 PM
