Sponsored by: CARiD
Cooling system expansion tank overflow
Old Jun 24, 2014 | 08:05 AM
whizzkid's Avatar
5th Gear
Default Cooling system expansion tank overflow
Hi,
I have a 2005 Freelander SE, and i have been experiencing an overflow of the water in the expansion tank after 5 mins of running the engine.
how can i fix this?
thank you
Old Jun 24, 2014 | 08:37 AM
dusty1's Avatar
gotta find the cause, before you can fix it.
5min = time to get up to operating temp.
would be good to have accurate coolant temp and I would test for gasses in the coolant.
Old Jun 24, 2014 | 10:10 AM
The 2 most common cause for this is either you have a bad coolant pressure cap or a cracked coolant bottle which, once they start cracking, don't repair well.
Has your engine overheated at all recently?
Old Jun 25, 2014 | 04:41 AM
whizzkid's Avatar
5th Gear
Thanks for the responses
No the engine hasn't overheated. even with this problem the temperature does not cross the normal level till all the coolant runs off.
the coolant bottle and cap has also been replaced
ewatk
Jul 9, 2020 05:17 PM
aguison
Nov 16, 2012 09:29 AM
bigfun
Dec 13, 2007 04:23 PM
pompano
Nov 5, 2006 10:29 AM
