Sponsored by: CARiD
Cooling System- Overheating/No Cab Heat
Old Nov 9, 2008 | 06:23 PM
boilerman's Avatar
Default Cooling System- Overheating/No Cab Heat
I noticed a problem in my cooling system when the cab was heating up intermittently. My first thought was that the thermostat wasn't operating properly. Then on my way home the engine overheated. I replaced the thermostat and filled the reservior up with coolant only to again have overheating, this time I had about half a gallon of coolant leak from some un-obvious location. I check my work on the thermostat, dry as a bone. I couldn't find the leak but suspect the water pump. Could a water pump cause overheating and the cabin not to heat? Thanks for help anyone!
P.S. I'm trying to learn how to work on my car as I plan on owning it for many years. It is very fun! I'm not trying to be cheap..
Old Nov 11, 2008 | 04:28 PM
jennifer's Avatar
4th Gear
Default RE: Cooling System- Overheating/No Cab Heat
Your problem sounds like mine, loseing coolant and overheating. I would be interested to hear if you find a cure
Old Nov 11, 2008 | 08:59 PM
hazletbassist89's Avatar
What year and how many miles?
Avoid driving as much as you can untill you can get this sorted out, a Rover engine can be completely ruined after a single overheat, so be VERY careful with your driving. If you have to drive at all stop if your needle even goes up just a little bit, you want to avoid driving if at all possible though.
Old Nov 12, 2008 | 07:35 AM
Because of the possibility of overheating and loosing the engine, I would fill the coolant bottle up, go staright to a shop, have them pressure test the system and get it fixed, "TODAY".
Let us know what they find.
kmccarthy88
Jun 7, 2015 06:56 PM
kdscott100
Aug 22, 2014 02:51 PM
PLOWER99
Jan 10, 2013 08:02 PM
Havoc556
Nov 1, 2011 08:48 AM
bulldozer32
Nov 12, 2010 03:00 PM
