Sponsored by: CARiD
Corrosion on a 2012 LR4
Old Jan 17, 2015 | 11:54 AM
srg.one3's Avatar
6th Gear
Default Corrosion on a 2012 LR4
I have been looking for a used LR4 for several months and recently expanded my search outside of my State (CA). I found the beauty I had been looking for and had a Land Rover Pre Purchase Inspection done to ensure no surprises.
For the most past inspection went well. However, the tech did note that there is "under side corrosion developing on Chassis and Exhaust System." The Service Advisor told me it is not much of a deal, but it does have me concerned, especially since I will not see the car prior to purchase.
I had the seller take a few pics, which I have attached.
I was looking for some feedback on if this is something that is I should not worry about, something that is an easy fix, or a vehicle I just need to pass on.
I appreciate any technical feedback!
Attached Thumbnails Corrosion on a 2012 LR4-img_5542.jpg   Corrosion on a 2012 LR4-img_0132.jpg
Old Jan 17, 2015 | 12:02 PM
OverRover's Avatar
" I appreciate any technical feedback"
No BS.......That's NOTHING!
Old Jan 17, 2015 | 12:49 PM
Wouldn't worry about that one bit
Old Jan 17, 2015 | 05:36 PM
OffroadFrance's Avatar
Exhaust rust is normal as it gets hot then cold then hot again. Road salt doesn't help that rusting process at all. The chassis rust is superficial and can be dealt with very easily, no worries there. Get a price for cleaning the underside and Waxoyl or similar coating inside the chassis and outside if you are concerned. I don't know what it costs in the US but I'd hazard a guess about $500-600 if done properly.
Old Jan 18, 2015 | 01:57 PM
srg.one3's Avatar
6th Gear
Thanks all! Now I can focus on all the other funs of a Rover
weezy
LR4
Jul 4, 2014 01:10 PM
TangoYank
Nov 1, 2012 06:37 PM
ryans4
LR4
Jul 12, 2012 03:38 PM
Kingfish
LR4
Jul 5, 2012 08:24 AM
jrb
Dec 7, 2011 06:46 PM
