Sponsored by: CARiD
courtisy lamps,not working when opening doors
Old Apr 9, 2011 | 10:27 AM
gargar's Avatar
4th Gear
Default courtisy lamps,not working when opening doors
hello ; i have a 2001 range rover 4.6 litre..and all of a sudden my dome lamps. stop turning on when any door is open,but it will turn on if i manualy push the button...i checked all fuses ok ..is there a courtisy dome lamp module or something like that?????????? please help me. solve this mysterrie
Old Apr 9, 2011 | 09:40 PM
Check all of the door latches, use silicon spray and lube them up, the trigger for the lights is in the latches.
Old Apr 12, 2011 | 08:53 PM
gargar's Avatar
4th Gear
Default Courtisy lamps innop
THANKS FOR THE REPLY,IF ONE LATCH IS HUNG UP/STUCK WOULD IT CAUSE ALL DOOR LATCHES TO FAIL ON TURNING ON LAMPS WHILE THE DOORS AND REAR POP UP DOOR??????
Old Apr 12, 2011 | 10:07 PM
Yes, because the courtesy lights are on a timer so as not to drain your battery if you leave a door ajar.
They all run off of the same timer, so if the drivers door is left open and the lights shut off then when you open another door the lights will not come on.
How to find the bad switch I have no idea.
Old Apr 19, 2011 | 09:28 PM
gargar's Avatar
4th Gear
Wink door latches /courtisy lamps
thanks spike .i appreciate it very much.i will check
rambo
Oct 17, 2013 10:13 PM
wynhd
Feb 11, 2012 02:30 PM
gargar
May 17, 2011 02:52 AM
dieselgeek
Oct 6, 2009 01:49 PM
abutoma
Mar 10, 2007 09:36 PM
