Sponsored by: CARiD
cricket sound when AC or heat is on
Old Jan 13, 2011 | 04:56 PM
mbarela's Avatar
Default cricket sound when AC or heat is on
i hear a constant cricket sound when i turn on the AC or heat...except for today...the day i took it in to be looked at.
have you ever experienced this? its so annoying.
any ideas for a fix?
Old Jan 13, 2011 | 07:37 PM
lordmorpheus's Avatar
Without even knowing what year or model of vehicle you have, I would say it is probably the bearing in the blower motor.
Options: replace the blower motor, or remove it and see if you can lubricate the bearing in the motor.
Old Jan 13, 2011 | 08:02 PM
You mean you can't even guess what is causing the noise???????????????????
When does it happen, if it is when you are trying to turn on the fan, it is the blower motor, either bad or with leaves in it.
mrossipir
Jul 4, 2014 10:29 PM
LRD2pdx
Feb 12, 2014 10:57 AM
jmason
Nov 17, 2013 06:39 AM
Aj6543
Nov 8, 2009 06:44 PM
wilkensrover
Jan 5, 2007 12:39 PM
